CAD tip CAD tip # 7365:
Question
When you try to install AutoCAD (or LT, AutoCAD Architecture, Mechanical, Electrical, etc.) 2011 or 2010 on Windows 7, you get an error message about the operating system not being compatible.
The problem is not in the compatibility of Windows 7 but rather in the improper version of AutoCAD being installed. For "Win7 64" you need the 64-bit version of AutoCAD. Make sure you are installing the 64bit version of AutoCAD included on your official installation media (some versions have a separate setup.exe in the x64 folder on the DVD). Most AutoCAD-based CAD products (since 2008) are distributed in both 32-bit and 64-bit versions. These 64-bit versions are officially supported in XP x64, Vista 64 (since 2008) and Windows 7 (since 2010).
ACAD2011ACAD2010ACLTADTCivilACADMACADE
16.5.2010   75016×
this tip shared by ARKANCE experts applies to: AutoCAD 2011 · AutoCAD 2010 · ACLT · ADT · Civil · ACADM · ACADE ·
Tip 14986:How to launch Autodesk Fusion online, in a web browser?
Back    All CAD Tips
Categ:
