CAD tip CAD tip # 8723:
Question
If you want to change the order of folders or drawings in an AutoCAD Plant 3D (or P&ID) project, select the folder or drawing in the Project Manager and drag it with the mouse (left button pressed) to the desired position.
PlantPID
30.7.2012   8615×
this tip shared by ARKANCE experts applies to: AutoCAD Plant 3D · PID ·
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 14675:How to find out the size of the asphalted area and changes over time in Pointscene?
Tip 13056:How to copy DWG Properties from one drawing to another?
Tip 12908:How to transfer settings between projects in Plant 3D?
Tip 11228:How to find the Revit version used to save a RFA/RVT file?
Back    All CAD Tips
Categ:
