Over 1.127.000 registered users (EN+CZ).
CAD tip # 7174:
Question
If you need to convert special "Point" objects (COGO points) in AutoCAD Civil 3D to standard blocks with attributes (point number, elevation), you can use the command AeccConvertPointsToSdskPoints (ribbon Default > Create terrain > Points > Create blocks from COGO points).
This command converts the selected points (group, window...) to standard AutoCAD block references (instances) - you can either use your existing, custom defined block, or the command creates a new, default block.
Civil2010
21.1.2010
35550×
this tip shared by ARKANCE experts applies to: Civil 3D 2010 ·
