CAD tip CAD tip # 7488:
Question
DWG drawing files saved by 32-bit and 64-bit versions of AutoCAD (and AutoCAD LT, AutoCAD Architecture, Mechanical, Map, Civil 3D and other industry versions) are fully compatible (identical).
ACADACLTADTACADMCivilMap
30.7.2010   15032×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD LT · AutoCAD Architecture · AutoCAD Mechanical · Civil 3D · AutoCAD Map 3D ·
Tip 15038:Texts exported from AutoCAD to PDF appear slightly smaller and misaligned.
Tip 14736:FATAL ERROR: (0x7ffd344f0005) acismobj20.dbx
Tip 12103:Random lines are displayed over my AutoCAD drawing.
Tip 11337:Convert 3D PDF files back to CAD models.
Tip 10903:How to import an Illustrator file (.AI) into AutoCAD (.DWG)?
Back    All CAD Tips
Categ:
