CAD tip CAD tip # 7491:
Question
If you need to annotate multiple points with their cartesian coordinates (X-Y labels) you can use the DIMORDINATE command (separate X and Y values) or a dynamic block with automatic attribute values - see e.g. the PtLabel block in the Block catalog.
ACAD
2.8.2010   65234×
this tip shared by ARKANCE experts applies to: ACAD ·
Tip 15138:AutoCAD Field formatting codes - full list.
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 15090:3DPlot - 3D math surfaces in AutoCAD.
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 14894:Importing CSV points in Map/Civil - ImportPoints vs. MapImport.
Back    All CAD Tips
Categ:
