CAD tip CAD tip # 11246:
Question
With the free AutoCAD utility Hatch2L you can easily hatch an area between two polylines. Just select the base and the top curve and this application adds any missing side connecting lines between endpoints, and hatches separately the areas "above" (green) and "below" (red) if the lines are crossing, plus calculates the areas "above" and "below" (fill, cut).
You can download the LISP application Hatch2L from DL Download, load it with APPLOAD and start it by typing the HATCH2L command.
You can then edit the hatch to change its color and style (hatch pattern).
ACADADTMapCivil
4.1.2017   28419×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD Architecture · AutoCAD Map 3D · Civil 3D ·
Tip 14942:How do I place specific types of entities on a specific DWG layer? (LAYER variables)
Tip 14386:Visual catalog of blocks defined in a DWG drawing.
Tip 13802:Dual-color hatches in AutoCAD.
Tip 13590:How to set the hatch background color?
Tip 13158:ScaleBB - scale multiple objects to their ref.points or bounding boxes
Back    All CAD Tips
Categ:
