CAD tip CAD tip # 7847:
Question
The command FIND does not stay zoomed on the located drawing text - when I dismiss the Find dialog, it goes back to the original view and the found text is lost.
This behaviour was observed in AutoCAD version 2009 and the unpatched version 2010. Other AutoCAD versions keep the text zoomed.
Please check if you have an updated version of AutoCAD 2010 - see the service packs on DL Download
ACAD2010ACAD2009
10.3.2011   13819×
this tip shared by ARKANCE experts applies to: AutoCAD 2010 · AutoCAD 2009 ·
Tip 14875:How to find the radius of a fillet and transfer it to other corners? FBE
Tip 14767:How do I model a thread in Fusion that is not listed?
Tip 14630:Extended ASCPOINT - import coordinates from CSV file, including blocks with attributes, GPS coordinates, etc.
Tip 14593:Revit is slow on a new workstation on structural and steel connections projects.
Tip 14519:QCS - Faster way to launch commands in Inventor (T4I)
Back    All CAD Tips
Categ:
