CAD tip CAD tip # 8778:
Question
It has probably happened to you that you accidentally not saved your extensive edits in an AutoCAD drawing (you answered "No" on the "Save changes?" prompt), or you accidentally quitted a new drawing, or a disk or network error occurred during saving of your drawing (in these situations neither the built-in AutoSave/SV$ nor BAK backup files will help).
In all these cases you could be rescued by the ARKANCE utility SureSave (see DL Download).
This LISP reactor stores a copy of the edited (changed) drawing on every save and every close of the DWG document (irrelevant if you answer Yes or No), on every N commands, and it also retains the AutoSave time-backup files. You can set the backup folder for with copies of the drawing (e.g. a SSD disk) and you can bulk delete old backups.
If necessary, you can easily restore the backup (copy) of the saved drawing. This application works automatically and does not affect the normal behavior of AutoCAD.
More details at SureSave
ACAD
24.8.2012   16808×   FAQ
this tip shared by ARKANCE experts applies to: AutoCAD ·
Tip 9428:Save DWG drawing automatically after every N commands.
Tip 4684:AutoCAD forgets its AutoSave (savetime) settings.
Tip 4345:What is the difference between .BAK, .SV$ and .AC$ backup files?
Tip 3506:Can I restore a drawing from an .ac$ file?
Tip 1813:Where to find my autosaved drawings?
Back    All CAD Tips
Categ:
