CAD tip CAD tip # 6920:
Question
If you want to rename all your layers, blocks or other AutoCAD drawing symbols by adding a common prefix or suffix, you can use the free PSrename utility.
The PSrename command allows to select the symbol table (Block, Dimstyle, Layer, Linetype, Style, Ucs, View) and to enter an arbitrary prefix or suffix string. Then it renames all selected symbols (e.g. layers) by adding this prefix or suffix string. It automatically skips renaming "protected" DWG symbols like the layers "0" or "DEFPOINTS", "AVE_RENDER" blocks, xref symbols, etc.
You can download PSrename from DL Download, load it with APPLOAD.
ACAD
8.9.2009   30964×
this tip shared by ARKANCE experts applies to: AutoCAD ·
Tip 14971:Why won't AutoCAD open raster images in .SID format?
Tip 14836:AutoCAD doesn't show my installed TTC font (TrueType Collection)
Tip 14641:Automatic naming of Inventor drawing sheets according to the first model (iLogic).
Tip 14523:Cannot rename view or level. Restore warning message.
Tip 14427:Set the number or description of the COGO point according to the nearest text.
Back    All CAD Tips
Categ:
