Over 1.127.000 registered users (EN+CZ).
CAD tip # 7308:
Question
If you want to insert (attach) a raster image in your AutoCAD drawing through an AutoLISP code, use the following command:
(command "_IMAGE" "_ATTACH" "img1=myfile1.png" '(0 0 0) 1.0 0.0)
The third parameter specifies the name of the image in the drawing and its disk filename. The next parameter are the coordinates of the insertion point and then follows the scale and rotation of the image.
ACAD
13.4.2010
20613×
this tip shared by ARKANCE experts applies to: AutoCAD ·
