CAD tip CAD tip # 7878:
Question
I am trying to input the offset distance as 17.3 and the drawing is in 1:2 scale, so I entered "17.3/2", but it doesn't work.
On AutoCAD prompts, you can directly input arithmetic expressions with integers (e.g. 17/3), but for operations on real numbers you need to use the embedded CALculator:
Offset distance: 'cal
>>>> Expression: 17.3/2
Continuing the OFFSET command.
Another option is to use the LISP evaluator:
Offset distance: (/ 17.3 2)
And another option is to use the QuickCalc - Ctrl+8.
ACAD
30.3.2011   24122×
this tip shared by ARKANCE experts applies to: AutoCAD ·
Tip 14861:RegExpCnt - LISP string replace function with arithmetic/counter-extension
Tip 14459:How to replace missing functions min() and max() in Revit expressions?
Tip 14417:Quick calculator on an AutoCAD keyboard shortcut.
Tip 14363:Yesterday's, tomorrow's, past or future date in the DWG drawing.
Tip 14223:Arithmetic operations for renaming blocks, levels, layouts...
Back    All CAD Tips
Categ:
