CAD tip CAD tip # 6762:
Question
If you want to reduce the responsiveness of object snapping - i.e. enlarge the area, where AutoCAD applies the osnap mode, increase the value of the APERTURE variable.
And vice-versa: if you need to increase the sensitivity, decrease this setting.
You can also use the Options dialog, the Drafting tab, the "Aperture size" setting.
ACADACLTADTCivilACADM
24.6.2009   39138×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD LT · AutoCAD Architecture · Civil 3D · AutoCAD Mechanical ·
Tip 14935:"Mechanical" osnap modes in AutoCAD Mechanical.
Tip 13819:Position and docking of the Measure palette in Inventor 2024.
Tip 13333:"Zero length line" warnings or misplaced vertices when importing vertex coordinates from scripts.
Tip 13307:How to teach AutoCAD Web app a new command?
Tip 11989:How to dimension an ellipse in AutoCAD?
Back    All CAD Tips
Categ:
