CAD tip CAD tip # 8097:
Question
If you want to select only lines of a given length from your drawing, you can use the LISP utility FilterLL.
This tool prompts for the shortest and longest length. From the selected lines (LINE objects) it then filters the individual objects so that only those matching the given length interval remain selected.
You can download the FilterLL.lsp application from DL Download, load it with APPLOAD and run it with the FilterLL command. You can use grip-editing on the selected lines or use the pre-selection in AutoCAD editing commands.
ACAD
21.7.2011   19035×
this tip shared by ARKANCE experts applies to: ACAD ·
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 14620:Converting object data (OD) to XData (XD) in AutoCAD Map 3D.
Tip 13878:SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions
Tip 13688:How to select all DWG objects of a certain type in AutoCAD LT? (texts, circles...)
Tip 13459:DWG drawing version history directly in AutoCAD.
Back    All CAD Tips
Categ:
