Over 1.124.000 registered users (EN+CZ).
CAD tip # 8800:
Question
If you want to apply the material (texture) "diamond plate" (floor plate) to your Inventor model, select the appropriate material from the predefined material library or create a new material with an appropriate texture and bump map.
In Inventor 2012 and older choose the color "Diamond plate". In Inventor 2013 choose the appearance "Diamond plates" or "Polished diamond plate".
Inventor2013Inventor2012
5.9.2012
33324×
this tip shared by ARKANCE experts applies to: Inventor 2013 · Inventor 2012 ·
