CAD tip CAD tip # 8713:
Question
Since AutoCAD 2000 you can use the PSETUPIN (or -PSETUPIN) command to transfer (copy, import) existing page setups from another .DWG file.
ACADACLT
19.7.2012   14435×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD LT ·
Tip 9331:What is contextual field and why it is not updated in a block?
Tip 9147:Batch publishing to PDF uses different margins than single prints.
Tip 8788:Batch unification of page setups in DWG files.
Tip 8580:Localization of Autodesk 2013 products using "Language Packs".
Tip 8499:Batch change of page setups and purging in DWG files.
Back    All CAD Tips
Categ:
