Over 1.127.000 registered users (EN+CZ).
CAD tip # 8449:
Question
Long AutoCAD tables (tables with many rows) may be difficult to place on drawing sheets. But you can wrap any table into multiple sections (columns) in AutoCAD or AutoCAD LT.
Grip-select the table and use the bottom center blue arrow (pointing down) to click and drag the wrap break-line to the desired position.
ACADACLT
6.2.2012
18388×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD LT ·
