Over 1.124.000 registered users (EN+CZ).
CAD tip # 9263:
Question
L.Larsen from Kingsbury, Inc. has sent us a core of an iLogic code for exploding a component pattern (see the Tip 8956).
Here is an extended version of this code which allows to select a pattern in the assembly tree and then makes all its members "independent" in a single step:
Inventor
24.5.2013
15282×
this tip shared by ARKANCE experts applies to: Inventor ·
