CAD tip CAD tip # 9887:
Question
If your Inventor crashes on opening some large models and the models can be opened without any problems on another PC, it is caused by the configuration of your Inventor workstation.
Your machine has got not enough system resources (RAM, disk space, certified graphics card), or there is a hardware problem (error in high bank of RAM, overlapping mapping on RAM and VRAM), or your Inventor is switched to a different graphics mode - see Options > Hardware.
It also may be caused by a more demanding (resource-intensive) visual style used in the respective models - your graphics need more resources than the graphics on another workstation to display it, and these resources are not available. Try to reset the appearance of the opened models using the application options - see Options > Display > Appearance > Use application settings:
Settings - Appearance (CZ version)
Inventor2015Inventor2014
25.6.2014   10688×
this tip shared by ARKANCE experts applies to: Inventor 2015 · Inventor 2014 ·
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 13513:How to quickly record a video from a CAD application or other Windows program? (replacing Screencast)
Tip 12994:In the dark Inventor environment, contrasting edges are not displayed.
Tip 12598:Unreadable system dialogs in Inventor (symbols, japanese, arabic)
Tip 12242:How to increase contrast between a constrained and underconstrained curve in an Inventor sketch?
Back    All CAD Tips
Categ:
