CAD tip CAD tip # 7884:
Question
You can start a new empty Inventor drawing from scratch without any custom styles, drawing resources, frames and title blocks. Use this trick to create a quick sketch-only drawing, or to start a new company standard template.
Just hold down the Ctrl+Shift keys while selecting a new drawing from the icon drop down menu (the "I" application menu or the quick-access toolbar).
Inventor2012Inventor2011
31.3.2011   12390×
this tip shared by ARKANCE experts applies to: Inventor 2012 · Inventor 2011 ·
Tip 15056:Incorrect creation date of the drawing on the sheet from Inventor.
Tip 15049:Inventor displays incorrect dimension lengths in my drawing views.
Tip 14969:Examples of AI prompts and the challenges of using the Autodesk Assistant AI feature for analyzing and generating CAD geometry in AutoCAD and Fusion.
Tip 14907:Why are the hole center marks in Inventor not aligned to the center of a circular part?
Tip 14869:How to generate a Regression curve through a set of points in AutoCAD or other CAD?
Back    All CAD Tips
Categ:
