CAD tip CAD tip # 6907:
Question
An attempt to use SOLIDEDIT to separate a 3D solid combined from multiple objects fails.
The option Body > Separate in the SOLIDEDIT command is to be used to separate multi-lump solids (with individual, spatially separated disjointed volumes), not for solids with a single continuous volume created e.g. by combining multiple intersecting 3D objects (Union).
ACADADTACADMCivil
3.9.2009   23137×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD Architecture · AutoCAD Mechanical · Civil 3D ·
Tip 12717:How to hollow out a 3D solid body in AutoCAD?
Tip 12248:How to remove fillet or chamfer from a 3D solid?
Tip 12013:How to trim 3D solids with other 3D solid (3D trim).
Tip 11252:Applying STRETCH to 3D objects in AutoCAD.
Tip 8484:How to apply material to a single face only?
Back    All CAD Tips
Categ:
