CAD tip CAD tip # 7376:
Question
A turned over text displayed upside down can be caused by several reasons in AutoCAD:
  1. The "Upside down" effect set in the current text style (STYLE command).
  2. The current USS set in the "backwards" orientation (upside-down).
  3. The current view set in the "backwards" orientation (upside-down).
  4. Text in a block or xref which is inserted as "rotated".
  5. If the text is a dimension text, the dimtext USS may get improperly transferred from a foreign CAD application, or the Text rotation (orientation) parameter is set (see the dim Properties, Ctrl+1). These situations can be fixed by the LISP utility FixDimensions - see DL Download.
ACAD
27.5.2010   51382×
this tip shared by ARKANCE experts applies to: ACAD ·
Tip 14509:AutoCAD linetypes - the A/R/U orientation options in complex text-linetypes.
Tip 13450:How to create a complex line type with text always upside down?
Tip 4886:Text always readable in the MTEXT editor.
Tip 4066:How to make rotated texts and block attributes "readable"?
Back    All CAD Tips
Categ:
