CAD tip CAD tip # 8512:
Question
If you have your AutoCAD or Inventor dialogs overflowing outside the screen, or the application icon (red "A", yellow "I", purple "R") is suddenly too small (with larger, inadequate ratio to the ribbon), it is probably caused by changed display settings (dpi) in Windows.
Start the Windows Control panels and check the setting Display (Appearance and Personalization > Adjust screen resolution), custom text size (dpi) - it should stay on 100% ("Smaller", the default), not 125% ("Medium") or 150% ("Larger") for the UI elements displayed properly.
ACADInv.Revit
6.3.2012   10217×
this tip shared by ARKANCE experts applies to: AutoCAD · Inv.Revit ·
Tip 15073:How to run an iLogic rule from the ribbon or with a keyboard shortcut?
Tip 15032:Naming PDF files from Revit based on sheet number and sheet size.
Tip 14957:Controlling Navisworks from the runstring.
Tip 14898:AlignO - aligning selected entities in Corel style.
Tip 14881:Suddenly, I can't resize the Open dialog box in Inventor.
Back    All CAD Tips
Categ:
