CAD tip CAD tip # 8515:
Question
If you want to delete all frozen, off or locked layers from your drawing, you can use the free add-on utility CADstudio FLayDel - see DL Download.
It deletes (erases) all layers (including their contents!), which are in the freeze, off or locked status. It avoids xref layers. This is an extension of the LAYDEL command.
ACADACAD2007
6.3.2012   25929×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD 2007 ·
Tip 14832:Convert polylines to alignments in Civil 3D.
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13675:Two PURGE commands in Autodesk Civil 3D.
Tip 13358:Restore the last deleted entity in the DWG.
Tip 12036:Sel2BlkRef (blockify) - replace repeating objects with block references
Back    All CAD Tips
Categ:
