CAD tip CAD tip # 8692:
Question
The "Revit Server" component for Revit 2013 and Revit 2012 is a part of the standard installation media. Go to "Install Tools & Utilities" on the Revit setup homepage.
Make sure you are installing Revit Server on a server computer, not your local PC workstation. It is possible to combine multiple versions of Revit Server on the same machine.
Revit2013Revit2012
18.6.2012   12775×
this tip shared by ARKANCE experts applies to: Revit 2013 · Revit 2012 ·
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 14307:How do I generate EDU licenses for the Autodesk license server?
Tip 14281:Mapped network drives (S:, T:, X:, etc.) are not available in my CAD application.
Tip 13633:How to run Revit, Inventor or Windows version of AutoCAD on macOS?
Tip 13402:Which products and features can I use for free with Flex Token licensing?
Back    All CAD Tips
Categ:
