CAD tip CAD tip # 10192:
Question
Internal calculations performed by Revit on expressions with parameters of the type "temperature" are always done in Kelvins, even when the project units are set to °C. In projects and RFA families, this may lead to improper repeated use the offset "zero temperature" - 273.15K - in expressions involving the temperature parameters.
Procedures and workarounds for proper correction of degrees Celsius temperatures are summarized in the blog post Counting with temperatures in Revit (°C vs. Kelvins) (in Czech) on our BIM blog NaZdi.cz ("on the wall").
Similarly, "temperature" expressions are evaluated in Autodesk Inventor.
RevitInventor
3.2.2015   9268×
this tip shared by ARKANCE experts applies to: Revit · Inventor ·
Tip 15078:New Heating and cooling loads analysis in Revit 2027.
Tip 13692:What is the precision in Revit?
Tip 12777:Arithmetic and trigonometric functions available in Revit expressions.
Tip 12624:How to enter dimensions in Revit using other units?
Tip 11494:Entering decimal values using fractions in CAD applications.
Back    All CAD Tips
Categ:
