Over 1.127.000 registered users (EN+CZ).
CAD tip # 7988:
Question
Autodesk Inventor 2012 includes internal translators for the following "foreign" and neutral CAD file formats and format versions (file import/export):
| Formát | Import | Export |
| AutoCAD 2D/3D (*.dwg, *.dxf) | R12-2012 | R12-2012 |
| Alias (*.wire) | version 10 and newer | - |
| CATIA V4 (*.CATPart, *.CATProduct, *.model) | all versions | - |
| CATIA V5 (*.CATPart, *.CATProduct) | R6-R20 | R10-R19 |
| IGES (*.igs) | all versions | 5.3 |
| JT Precise (*.jt) | 7.0, 8.0, 8.1, 8.2, 9.0, 9.1, 9.2, 9.3, 9.4. 9.4 | 7.0, 8.0, 8.1, 8.2, 9.0, 9.1, 9.2, 9.3, 9.4 |
| NX (*.prt) | 3-7.5 | - |
| Parasolid (*.x_b, *.x_t) | up to ver 23.0 | 9.0-23.0 |
| Pro/ENGINEER (*.prt, *.asm) | up to ver 5.0 | - |
| Pro/ENGINEER Granite (*.g) | up to ver 6.0 | 1.0-6.0 |
| Pro/ENGINEER Neutral (*.neu) | all | all |
| SAT (*.sat) | 4.0-7.0 | 4.0-7.0 |
| SolidWorks (*.prt, *.sldprt, *.asm, *.sldasm) | 2003-2011 (2011 in sp1) | - |
| Rhino (*.3dm) | up to version 4.0 | - |
| STEP (*.stp, *.ste) | AP214, AP203E2 | AP214, AP203E2 |
| STL (*.stl) | - | all |
| XGL/ZGL (*.xgl/*.zgl) | - | all |
Other formats are available as add-on translators (e.g. VRML - .wrl).
Inventor2012
19.5.2011
17747×
this tip shared by ARKANCE experts applies to: Inventor 2012 ·
