CAD tip CAD tip # 7754:
Question
If you need to globally switch standard text masks for selected MText objects on or off (or toggle), you can use the LISP utility TMaskOnOff. You can download it from DL Download.
Load the LSP file with APPLOAD and run the command TMASKON, TMASKOFF or TMASKONOFF.
NB: for standard masks you cannot use the TEXTMASK and TEXTUNMASK commands
If you want to switch off (disable) the background fill for Texts, Leaders and Dimensions, you can use the UnMask utility - see DL Download.
ACAD
25.1.2011   27239×
this tip shared by ARKANCE experts applies to: ACAD ·
Tip 14268:How to set the background mask color to BYLAYER?
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 11289:Adding, multiplying and rounding numbers inside DWG drawing texts - NumInText.
Tip 7249:How to select all drawing entities containing a given text?
Tip 6433:Force layer for selected commands (objects) - FLay.
Back    All CAD Tips
Categ:
