CAD tip CAD tip # 9899:
Question
If you need to re-initialize (reload) the alias definition file ACAD.PGP, you can use beside the REINIT command also the system variable RE-INIT.
Setting RE-INIT to the value of 16 you will invoke one-time reloading of the ACAD.PGP file without any dialog (e.g. for scripts and menu macros).
ACAD
14.7.2014   14302×
this tip shared by ARKANCE experts applies to: AutoCAD ·
Tip 14354:Bit-encoded value of the undocumented variable INPUTSEARCHOPTIONFLAGS.
Tip 11743:How to open a HTML document from AutoCAD?
Tip 9905:Double-click on a text gives: Unknown command DDEDIT.
Tip 8538:How to open a PDF file from AutoCAD?
Tip 7051:What is the flag (0-15) in the command alias editor?
Back    All CAD Tips
Categ:
