  Visitors: 7897
CAD tip CAD tip # 12546:
How to renumber handles of selected DWG entities?
A - answer Every drawn object in a DWG database has assigned its internal, incremental and unique ID, so called "handle". Common editing commands do not change it afterwards. Through this ID, the object (entity) may have other information attached, e.g. from a SQL database, or relationships with other objects.
If you want - for some reason - change these internal IDs and e.g. change the internal order of entities (a.o. they are displayed in this order by default), you can use the Express Tools command CDORDER. In its dialog, use the option "Handles" and perform any change of order.
You can verify the change e.g. with our LISP utility History.
ACAD
24.3.2020    8982×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 12403:Get center point of a group of selected objects.
Tip 12297:Which CAD formats are supported in the Autodesk Manufacturing Data Exchange Utility?
Tip 11017:How to select a DWG object by its internal ID, its "handle"?
Tip 8128:How to quickly get the real color of a drawing entity?
Tip 8121:Do you know the AutoCAD command "space invaders"?
