CAD tip # 6947:
Question
If you want to run your AutoCAD without creating an empty "unnamed" drawing "Drawing1.dwg" (Zeichnung1.dwg, etc.), you can use a simple script to avoid it.
In the properties of the AutoCAD icon on your desktop edit the line Target and add a parameter:
/b closee.g.:
"C:\Program Files\AutoCAD 2010\acad.exe" /b closeNow create a simple text file CLOSE.SCR in AutoCAD search path (so it can find it) - this file will containg a single line (ended with Enter):
_CLOSE
If you start AutoCAD using this icon, the empty DWG drawing will be immediately closed.
Another option is the variable STARTUP.
ACAD
18.9.2009
19236×
this tip shared by ARKANCE experts applies to: ACAD ·
