CAD tip CAD tip # 8705:
Question
To submit, share, or concurrently edit a DWG drawing via internet you can use the cloud service "Autodesk 360" - directly from AutoCAD or AutoCAD LT. So you don't need to send the drawing as an e-mail attachment, via FTP, on an USB stick, or in similar ways.
Just use the function "Share Document" or "Collaborate Now" in the AutoCAD Online ribbon (the commands ONLINESHARE and ONLINECOLNOW):
Online ribbon (CZ version)
In both cases, your DWG file is uploaded to your personal storage in Autodesk's web-cloud. The function Collaborate directly launches the online version of AutoCAD - AutoCAD 360 (WS) - where you can view and edit the drawing (anywhere and on any device - tablet, phone), either alone or in real-time collaboration with your collegues - see the video example:
ACADACLTDWGACADWSACAD360
17.7.2012   28447×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD LT · DWG · ACADWS · AutoCAD ·
Tip 14007:Workaround for the missing (vlax-create-object) in AutoCAD LT (voice, clipboard, etc.)
Tip 14006:Universal MsgBox in AutoLISP.
Tip 8618:Mapping Autodesk Cloud (AutoCAD WS) as a network disk drive.
Tip 8606:Configuring remote printing from AutoCAD WS Mobile.
Tip 8566:Concurrent editing of a DWG file from two remote PCs.
Back    All CAD Tips
Categ:
