CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 1265
CAD tip CAD tip # 8703:
File formats compatible with Autodesk BIM 360 Glue.
A - answer The cloud application Autodesk BIM 360 Glue is integrated with CAD/BIM tools in Autodesk Building Design Suite and Infrastructure Design Suite. But you can also use it to coordinate BIM project data in other CAD formats.
BIM 360 Glue supports the following file formats:
  • DWG
  • DXF
  • 3DS
  • DWF/DWFx
  • IPT/IAM (Inventor)
  • DGN
  • IGES/IGS
  • STEP/STP
  • IFC
  • JT
  • X_T/X_B (Parasolid)
  • SKP (SketchUp)
  • KMZ
  • PTS/PTX (point clouds)
  • 3DXML
  • PRC (Adobe 3D)
  • VRML/WRL
  • MAN (MicroGDS)
  • DRI/DRV (Intergraph PDS)
  • CIS/2
  • RVM (Aveva PDMS)
  • PD/_PD/CADDS (CADDS)
  • CGR (Catia)
  • CATPRODUCT/CATPART (Catia)
  • EXP/MODEL/SESSION (Catia)
  • ASM/PRT/SLDASM/SLDPRT (Solidworks)
  • DAE (Collada)
  • IF (Allplan)
  • PLY (Polygon)
  • PRC
  • PRT (Pro/Engineer)
  • STL
  • U3D
  • OBJ
  • WMF/EMF
  • PNG/JPG/GIF/BMP/TIFF
  • AVI
See also Autodesk BIM 360
BIM360
16.7.2012    1768x
Comments   Tell a friend
applies to: BIM360 ·
Tip 9250:How to upload entire folders to the cloud Autodesk 360?
Tip 9167:The Autodesk 360 icon and controlling cloud synchronization (2014).
Tip 9156:I have enabled saving to cloud but my newly saved DWG is not in the cloud.
Tip 8921:How to terminate Autodesk Sync (AdSync.exe)?
Tip 8852:Publish interactive 3D models on the web with Autodesk 360.
The easiest way to share DWG drawings online. « | » Preset perspective viewing for Inventor models.
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
