CAD Forum
Cesky English Deutsch
Login:
 Visitors: 1294
WWW server of the XANADU company (formerly: CAD Studio) Become a fan of CADforum on Facebook
CAD tip CAD tip # 7164:
The NLS files required to convert the text entities...
A - answer When opening a DWG or DXF file you may get this error message:
The NLS files required to convert the text entities and symbol table name in your drawing code page undefined to ANSI_1252 can not be found or are not installed on your system... To install the missing NLS files, double click the Regional Settings icon in the Windows Control Panel.
This error indicates that the file contains texts encoded in a codepage which is not supported (installed) in your Windows, or - as in this case - that the source code page is "undefined".
You may want to add the missing language support to your Windows - e.g. asian languages, cyrillic (Control Panel > Languages, Regional settings), or you can just ignore the message (especially if the codepage is "undefined"). Just check the drawings texts and symbol names (block names, layer names...) for possible garbled characters, missing accents, etc.
This message may also be a result of the ACAD.VLX virus.
ACAD
15.1.2010    719x
Comments   Tell a friend
Share tip: Digg it! Del.icio.us Facebook Technorati StumbleUpon
applies to: AutoCAD ·
Tip 5837:OpenType font support in AutoCAD and Revit.
Tip 5783:Language pack missing - warning on DWG open.
Tip 4946:Loading Page setups from a template drawing.
Tip 4894:Setting pagesetup for multiple layouts.
Tip 3976:Where to find arabic fonts for AutoCAD?
Search CAD blocks directly in Windows 7 Search. « | » DWG - DGN format converter.
Have we helped you? If you want to support the CAD Forum web service, consider buying one of our CAD applications, or our custom software development offerings. You may also add a link to your web - like this "fan" link: CAD Forum - tips, utilities, blocks for Autodesk products
Export 3D VRML scenes from AutoCAD and Inventor 2010
VRMLout More info
XANADU (CAD Studio) is not responsible for possible problems that may occur as a result of using any of these tips.
