CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 2001
CAD tip CAD tip # 7766:
Using OpenOffice/LibreOffice Calc with Autodesk Inventor.
A - answer For some table and parametric operations (e.g. iParts, iAssemblies, threads, Content Center publishing), Autodesk Inventor requires Microsoft Excel to be installed (see the system requirements), and it is not compatible with other spreadsheet applications like Calc from OpenOffice.org, resp. Libre Office, GNumeric, Lotus Symphony, 1-2-3, KOffice, StarOffice, GNome, WPS, etc.
The file compatibility (XLS/XLSX) is not important for this, the inter-application communication depends on the API and object model compatibility of the spreadsheet software.
Inventor2011Inventor2010Inventor2009
30.1.2011    4294x
Comments   Tell a friend
Tip 9066:Table embedded into an Inventor drawing is not visible in DWF.
Tip 8872:Track who and when has changed each entity in a DWG drawing.
Tip 8677:Associative DWG table of line length totals (by layer).
Tip 8559:How to export AutoCAD drawing texts to Excel?
Tip 8538:How to open a PDF file from AutoCAD?
Cannot use Alt+nnn keyboard shortcuts in AutoCAD. « | » Multileader with special framing.
