Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
RSS discussions
Discussion Discussion forum
  FAQ FAQ  Forum Search Search  Events Events  Register Register  Login Login
Topic ClosedDIMENSION.
 Post Reply Post Reply
Author
Ferna View Drop Down
Groupie
Groupie
Using: 2009
Status: Offline
Direct Link To This Post Topic: DIMENSION.
    Posted: 08.Oct.2009 at 21:29
Normally in my job I have primary Units (Imperial) and Alternate Units (Metric), I need to know how can I get rid of the Primary Units (Imperial) sometimes and work just with Alternate Units(Metric) without explode the Dim. and delete the Primary Unit which I think is very improper.
Really appreciate your help on this.
TXS,
Ferna
Ferna
Back to Top
Arben.Allaraj View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Posted: 09.Oct.2009 at 09:13
TXS,
Ferna
Maybe you should create new Dim Styles metric & Imperial and use when you need.
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Back to Top
Groupie
Groupie
Using: 2009
Status: Offline
Direct Link To This Post Posted: 09.Oct.2009 at 14:10
there is not other way to solve this, other than create another dim. type?
Ferna
Back to Top
krish_architect View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 10.Oct.2009 at 05:57
hi ferna....
it's me again...with another bizarre solution i guess
give the command "ED" then click on the dim text...you can edit the dimension as per your need....
Back to Top
Groupie
Groupie
Using: 2009
Status: Offline
Direct Link To This Post Posted: 14.Oct.2009 at 14:53
TXS for your feedback Krish, it could be a temp. solution but it  is not the right one, I was thinking that DIM. command had the variable option to choose if I want to keep the alternate Dim. or the Primary Dim. other than create a new style or Edit.
TXS
Ferna
Back to Top
p3.1416l View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 23.Oct.2009 at 20:45
Hi everyone
I think you should edit your dimension style. By setting the right Scale Factor in the Primary Units tab, you should get the right dim as desired.
As you know 1 inch= 25,4 mm so you now can set the right scale factor
Less is more
Back to Top
nameci View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 24.Oct.2009 at 04:33
Hey Ferna,
A good way of doing what you want is to set up a new dim style (eg. for metric), make the new dim style current, then type dim enter, up enter, then select the entire drawing and hit enter. This command will update all of the dimensions to the selected dim style.
Hope that helps,
nameci
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,082 seconds.
