Over 1.095.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
New AutoCAD 2026 commands and variables.
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply ![]() |
Author | |
Tankman ![]() Senior Member ![]() Joined: 27.Nov.2009 Location: United States Status: Offline Points: 220 |
![]() Posted: 20.Jan.2010 at 17:57 |
uploads/20100121_010211_CZ-Horizontal-T.dwg
Not a newbie on the boards and have used AutoCAD for 'bout 10 years.
All my drawings have been done using model space, 1:1 scale.
Makes life easy. I scaled (used to) my title block to fit around my drawing in model space. FYI. All my printing is done 8-1/2" x 11 (laser letter) and/or *.pdf which I fit to the paper (letter) size.
I am now trying to work with drawings which I have two layers; i.e.: model & title block. Having some fun with this but, stumped on how
to proceed.
All works well except, title block layer, is sometimes overwhelmed; i.e.:
a drawing in model space that might be 15 ft long, doesn't scale properly in my title block layer.
I do like the idea having a title block layer where I can't edit the drawing done in model space.
Where am I goin' wrong? Might this be, "Can't teach an old dog new tricks?"
I've attached a *.dwg file for show 'n tell. What am I doin' wrong? Edited by Tankman - 21.Jan.2010 at 01:03 |
Tankman
"When the well's dry, we'll all know the value of water." |
tulip3D ![]() Senior Member ![]() Joined: 23.Jul.2009 Location: United States Using: AutoCAD2011, Inventor2011 Status: Offline Points: 427 |
My suggestion would be to scale the object down to the title block, as if in the layout tab (paperspace) with a viewport. Although, maybe simply using paperspace and a veiwport would solve your problem...I think.
Im not clear on what exactly is not scaling; model geometry, which could be on any layer? Or your title block, which is on a 'title block' layer?
I added a drawing, using model and title block views to further explain my dilemma.
Guess my scale is off in one view or another(?).
Tankman
Rman ![]() Groupie ![]() Joined: 14.Nov.2007 Status: Offline Points: 45 |
Mr Tankman,
My suggestion is try learn how to work with Layout (Paper Space) when comes to put in title block instead of Model space. I would suggest you as well migrated from plotting in Model space to Paper space. You 'll found that your life be more easier. Edited by Rman - 21.Jan.2010 at 07:31 |
Thanks Rman! After playin' around a bit, think I have it down pat (well, almost).
I'm working in model space but resize and or adjust view in model and/or paperspace! Good deal! Thanks again!
Tankman
Post Reply ![]() |
Tweet
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,129 seconds.
