Discussion forum
CAD discussion |
Assignment to a family not possible |
Post Reply |
Author | |
Ekrut
Newbie Joined: 27.Sep.2022 Location: Germany Using: Revit Status: Offline Points: 2 |
Post Options
Thanks(0)
Posted: 27.Sep.2022 at 11:59 |
Dear Sir or Madam,
I am currently working on importing IFC files into Revit and then using a link to generate data output to Sidoun Globe (AVA-Software). My problem is that the data output in Sidoun Globe only happens when the objects are assigned to a family in Revit. Now it is that I cannot set a system family for 4 out of 5 walls. I have compared all parameters and tried by different ways to set a family - but without success. Maybe you have an idea what setting I could make to be able to assign a family to the respective component (wall). I use Revit 2020.2.9. With kind regards Ekrut |
NestorA13
Newbie Joined: 09.Mar.2023 Location: México Using: Autocad Status: Offline Points: 1 |
Post Options
Thanks(0)
NOHUIH9UH
TECH 011
Groupie Joined: 18.May.2023 Location: Pakistan Using: AutoCAD2023 Status: Offline Points: 34 |
Post Options
Thanks(0)
Manual workaround is suggested.
Stay curious and keep exploring
Post Reply | |
Tweet
This page was generated in 0,469 seconds.
