Discussion forum
CAD discussion |
3ds max error opening on the icon and error win7 |
Post Reply | Page 12> |
Author | |
Tamara001
Newbie Joined: 01.Feb.2011 Location: Brasil Using: AutoCAD006, AutoCAD2008, 3ds Max 2011, Status: Offline Points: 7 |
Topic: 3ds max error opening on the icon and error win7 Posted: 08.Feb.2011 at 16:49 |
Hello everyone I'm new here. Sorry for bad English, I am Brazilian and I sent in googletranslate.
I'm in trouble and do not know how to solve this I have a pc with windows 7 and when I install it 3ds 2010 it installs without errors but very fast weight when it is closed to open only opens at third or fourth attempt and when I open a cube (for example.) and I modfy screen when I click on the list it closes without more speech than an error occurred and had to be closed already installed uninstalled again deleted all records but no change. still the same thing 2011 also installed the trial version directly from the Autodesk Web site and happens to same detail that also have a pc with win vista and it works without any normal Error already installed it on xp and tb gave no error, only the alias cube screen rotation it was gone but otherwise all was normal I do not know what else to do please help me Att: Tamara |
TAMARA
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 08.Feb.2011 at 18:14 |
Works on XP.
Works on Vista.
Doesn't work on Win7 yet it installed with no problems.
Very strange.
Is all software 32-bit?
Are you getting an error message? If so, what does it say, word for word? Edited by John Connor - 08.Feb.2011 at 18:16 |
<<AutoCAD 2015>> |
Tamara001
Posted: 08.Feb.2011 at 18:54 |
Opa's not an error message
when it closes, just click on it when he has not closed any of the message, go to task manager and 3ds max to add it. When I click on the "modify" it just closes, does not inany mistake, only that: "APPLICATION 3DS MAX stopped working, a problem caused the program to stop working correctly. Windows will close the program and notify you if a solution isavailable" Already downloaded the hotfix but did not change anything I was using 2011 but had the same problem downloaded the 2010 and even that tabetter than the 2011 but with the same errors. I saw the site of Autodesk 3ds max 2010nao is compatible with Windows 7 but I'm usingit in compatibility mode for Windows XP Service Pack 2 and run program asadministrator. I've seen other people complain that the program does not open, nor of any error messages, but no solutions. must be program error My windows7 is 32bit |
TAMARA
John Connor
Posted: 08.Feb.2011 at 19:43 |
Maybe your Windows Registry got corrupted. Did you create a Restore point before loading the new software?
Is all software legal?
<<AutoCAD 2015>> |
Tamara001
Posted: 08.Feb.2011 at 19:59 |
Well then, I did a restore point.
Do not know much about these things. 3ds max 2011 trial version I got directly from the Autodesk website. Should not get this problem right? I know someone who is having the same problem that I have even formatted thecomputer and still not resolved. |
TAMARA
John Connor
Posted: 08.Feb.2011 at 20:05 |
The AutoDesk website in the U.S.? If so, that could be the source of your problem. The version you are trying to run would not be for use outside of the U.S.
<<AutoCAD 2015>> |
Cad64
Senior Member Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 08.Feb.2011 at 21:28 |
Does your Win 7 computer meet the minimum system requirements in order to run Max? What are your full computer specs?
Online Portfolio: http://www.rdeweese.com/
Tamara001
Posted: 09.Feb.2011 at 11:21 |
Then John, the Autodesk Web site of Brazil does not offer any program downloadsthem, if I mistake not only AutoCAD. but I think it is not. always worked in other windowsand only in July that is with this type of error.
the other issue is the system requirement windows 7 that he supports but have alreadynoticed this, detail that 3ds max 2011 is giving more problems than 3ds max 2010version that has no windows 7. other details have also installed AutoCAD 2006 and works normally without any problem or error, even if not supported. I think it's very AUTODESK error or even Windows 7. 3ds max since 2010 has given meproblems in Windows XP and 7, but never had a problem with Vista, and looks thatWindows Vista was considered crap by many. |
TAMARA
John Connor
Posted: 09.Feb.2011 at 11:59 |
I believe AutoDesk has U.S. versions of their software and versions for other countries or regions of the world. I think you should contact AutoDesk directly for help with your problem. |
<<AutoCAD 2015>> |
Tamara001
Posted: 09.Feb.2011 at 12:23 |
Sure that only Autodesk since I know, no offers versions for Brazil, so that there is not3ds max version in Portuguese, here we always use the U.S. version, because it onlysaw the pirated version in Portuguese and does not provide for the commands are all different from what we learned in English, translated it, where in any course or even in college we learned straight from the U.S. version and also the installation is always donethe U.S. site because the Brazilian site redirects to the U.S. site to download.
but anyway thanks for everyone's help |
TAMARA
Tweet
This page was generated in 0,465 seconds.
