Over 1.124.000 registered users (EN+CZ).
CAD tip # 8587:
Question
The command WORKFLOW (and its commandline version -WORKFLOW) is available only in the extended AutoCAD 2013 supplied in the "AutoCAD Design Suite" (or in another Design Suite package).
The WORKFLOW command starts a dialog where you can invoke or edit a workflow automating data transfers to one of other applications in your Design Suite - e.g. 3ds Max or Showcase.
You can also find the workflows functionality under the AutoCAD application menu ("A"), in "Suite workflows".
ACAD2013DesignSuite
16.4.2012
14114×
this tip shared by ARKANCE experts applies to: AutoCAD 2013 · DesignSuite ·
