CZ | EN | DE
Login or
registration
  Visitors: 3921
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedInsert tree blocks with different canopy/trunk
 Post Reply Post Reply Page  12>
Author
geocadguy View Drop Down
Newbie
Newbie
Using: Autocad 2010
Status: Offline
Direct Link To This Post Topic: Insert tree blocks with different canopy/trunk
    Posted: 17.May.2014 at 19:26
Hello,
I have to insert about 1000 3d trees into a cad drawing. I can make a script file to insert the tree block I have created multiple times - that`s easy. What I`m trying to find out is how to insert multiple trees with different canopy and trunk sizes and tree height. The tree I`ve got is made up from a 3d solid sphere and a solid cylinder. Any help would be much appreciated.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 17.May.2014 at 20:57
1000 trees of varying height/diameter all derived from one tree block?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autocad 2010
Status: Offline
Direct Link To This Post Posted: 17.May.2014 at 21:18
Yes if that`s the easiest way of doing it. The trees will be surveyed individually so the tree height, canopy and trunk diameter of each one will be known. I am thinking to incorporate these dimensions into an automated block insertion task using only one (dynamic?)block.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 17.May.2014 at 22:35
You cannot create a 3D dynamic block in AutoCAD that I know of.
<<AutoCAD 2015>>
Back to Top
msplcdykee69 View Drop Down
Senior Member
Senior Member
Using: Civil 3D, Map, Inventor, Mechanical, & Electrical
Status: Offline
Direct Link To This Post Posted: 18.May.2014 at 06:33
you could do it some what similar to what I have done to sports fields dynamic block and a landscaping dynamic block for different size trees and shrubs but my number is set to a dozen and not so much a size but different shape and color... you would have all you number and canopy sizes in there and then just pick each time you needed it from one block...
Engineering Manufacturing Medical Cables/Adjunct Instructor Engineering Graphics/Engineering Computations and Careers
msplcdykee69@yahoo.com
Shawn
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.May.2014 at 11:40
mspl: Yes, while you can create a 2D dynamic block just as you mention the OP wants to use a 3D block.  Unfortunately you cannot create a 3D dynamic block.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autocad 2010
Status: Offline
Direct Link To This Post Posted: 18.May.2014 at 12:50
Thank you guys. I will try to create a lot of tree blocks as Shawn suggested.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.May.2014 at 15:12
And what good will 2D tree blocks do you in a 3D drawing?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autocad 2010
Status: Offline
Direct Link To This Post Posted: 18.May.2014 at 19:37
They all will be 3d with different dimensions and I am planning to write a script file to insert the ones I need automatically.
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 18.May.2014 at 22:20
John Connor you can create blocks in X, Y, Z directions and then import them into a dynamic block... I did it last night as a test with a few 3D trees I made.. Can be done just takes a little work.
Shawn
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,547 seconds.
