Over 1.110.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
LTunlimited RSS
RSS robots
Topic: Maximum Active ViewportsPosted: 18.Feb.2011 at 12:51 |
Ever make a new viewport and realize that another one has suddenly gone blank? And when you try to turn it back on, a different one goes blank? Meet MAXACTVP. This system variable, stored in each drawing, controls the number of viewports in a layout that can be displayed at one time. These days, the default value is 64, but it used to be 16, and since it’s a per-drawing setting you might still have a bunch in your library with that setting. So if MAXACTVP is 16, and you create a 17th viewport in the layout, one of them will have to be turned off. This does not affect plotting, fortunately, but it’s still a little disconcerting to see those blank viewports floating around. Chances are your computer has enough power to show all the viewports you could possibly want to create, so go ahead – set it to 64. Or higher. (But I think it’d have to be a pretty big sheet to get more than 64 viewports on it!)
Go to the original post... |
LT Unlimited - Autodesk blog by Kate Morrical
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,141 seconds.
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](/common/arkance_186.png)
Topic Options
