RSS discussions
Discussion Discussion forum
Topic ClosedSupports for piping
 Post Reply Post Reply
Author
kicker View Drop Down
Newbie
Newbie
Using: Autocad 2012
Status: Offline
Direct Link To This Post Topic: Supports for piping
    Posted: 28.Nov.2013 at 15:20
hello .
I have one doubt...
when we are drawing a pipe line... or an isometric...  when its to be defined  the supports ?? how its normally the best way to do ?? are there librarys of supports for pipes of big and small diameter ?? or we should do all the supports ??
thx...
Back to Top
hugh anderson View Drop Down
Newbie
Newbie
Using: autocad 1990 to 2014
Status: Offline
Direct Link To This Post Posted: 28.Nov.2013 at 22:10
you require thrust bocks for steel pipelines on all underground pipeline
for above ground lines you need concrete supports and suitable steel
straps at joint positions
hugh
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 28.Nov.2013 at 23:16
AutoCAD 1990?  Never heard of it.  I have heard of Release 9 and 2000.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autocad 2012
Status: Offline
Direct Link To This Post Posted: 29.Nov.2013 at 00:05
thx for the answer....
Hugh... if i understand well... you are saying that there are blocks of supports in inventor ,  to put in the drawing   ?? where  can i see that if they exist  ?
f they not exist... its means that we need to drawn them by " hand " ( in the inventor by good old school :)  correct ?
 yes.. i know that if the pipe in going above the floor.. . we need to put  first a concrete support.. and after that we finallized with a steel support... .. normally done in paper mills  , refinerys  etc.....
cheers :)
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 29.Nov.2013 at 00:17
Thrust blocks are used on water pipes that are buried in the ground.  Sanitary sewers and drainage pipes don't require thrust blocks.
Edited by John Connor - 29.Nov.2013 at 00:18
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autocad 2012
Status: Offline
Direct Link To This Post Posted: 09.Dec.2013 at 23:32
ok... but i am talking about pipes above the ground...
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,258 seconds.
