Discussion forum
CAD discussion |
Best Software to Convert PDF to ACAD |
Post Reply |
Author | |
kadar
Newbie Joined: 19.Mar.2014 Location: Singapore Using: ACAD 2014 Status: Offline Points: 4 |
Topic: Best Software to Convert PDF to ACAD Posted: 19.Mar.2014 at 07:13 |
Hi,
I'm given a task to convert PDF to ACAD and the software that I'm currently using don't give good output. It takes me a lot of hours to tidy up the output. Maybe you can suggest the software which you knew that is best for this task. Thank you |
Impossible is only a state of mind and not real
philippe JOSEPH
Senior Member Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1428 |
Posted: 19.Mar.2014 at 07:33 |
Hello kadar, I use the free software : www.anydwg.com and it's really amazing.
You will have to check for correctness and not relly 100% on it but it provides very good results.
Some horizontal text are to be rotated by +90° to be just like the original PDF that you will have under your eyes for a good check ( you can take all of them and affect the correct rotation with the properties pallette CTRL+1 ). Edited by philippe JOSEPH - 19.Mar.2014 at 11:03 |
kadar
Posted: 19.Mar.2014 at 07:51 |
Hi Philippe, Thank you for the suggestion. |
nandcx
Newbie Joined: 19.Mar.2014 Location: Indonesia Using: Autocad 2010 Status: Offline Points: 1 |
Posted: 19.Mar.2014 at 09:27 |
Robert_D
Senior Member Joined: 21.Oct.2013 Location: United States Using: BricsCAD v21, AutoCAD2006 Status: Offline Points: 207 |
Posted: 19.Mar.2014 at 15:20 |
Anydwg is free? I've been using Print2Cad http://www.backtocad.com/engl/engl-pdf-dwg.html with success for some time (not free). |
philippe JOSEPH
Posted: 19.Mar.2014 at 15:28 |
Hello Robert_D, I'm using www.anydwg.com as a trial release with the limitation of doing 3 files at one time for some times and it's OK from a certain time now.
Robert_D
Posted: 19.Mar.2014 at 17:02 |
As a free option, I have used Ghostscript & GSView w/ pstoedit plugin. It works acceptably for modest size files (not as well as paid options). |
philippe JOSEPH
Posted: 20.Mar.2014 at 20:28 |
Robert_D, recently I had to turn a "protected" 161 pages PDF file to DWG.
Ten of the last pages where plans that I couldn't "extract" from the "protected" PDF file. I launched the convertion and got 350 separeted good files and selected the one that I wanted easily because of the automatic number they had. We use PDF to DWG 3 of 4 times a year and it's OK for me.
Edited by philippe JOSEPH - 20.Mar.2014 at 20:30 |
Post Reply | |
Tweet
This page was generated in 0,455 seconds.
