CZ | EN | DE
Login or
registration
  Visitors: 6593
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedProblem selecting objects
 Post Reply Post Reply
Author
jmontesmx View Drop Down
Senior Member
Senior Member
Using: AutoCad2017
Status: Offline
Direct Link To This Post Topic: Problem selecting objects
    Posted: 02.Jul.2015 at 02:39
Why? when I select objects to copy and take of different parts of the drawing, to paste them into another area, if I was not seeing all the copy screen only paste those who were in it.
Is there a system variable to change this ?
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 02.Jul.2015 at 07:10
Hello jmontesmx, if it's in the same file you don't have to copy/paste, use simply COPY.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 02.Jul.2015 at 11:49
If you wanted to copy all the objects in the drawing even if they are not shown on your screen then you should have used the COPY command with the ALL option.
Now, are you copying within a drawing or between two different drawings?
Edited by John Connor - 02.Jul.2015 at 11:50
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCad2017
Status: Offline
Direct Link To This Post Posted: 02.Jul.2015 at 20:58
The problema is in the same file Philippe, I used the word paste to describe the word "pegar" in spanish, but you are right I use only the command copy.
Back to Top
Senior Member
Senior Member
Using: AutoCad2017
Status: Offline
Direct Link To This Post Posted: 02.Jul.2015 at 21:07
Thanks Jhon, I am copying only in one drawing, try as you suggest, but the whole picture is copied and only need to copy certain parts not all.
This happens to me all the drawings for that reason  the question whether it is a system variable that must be corrected.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 03.Jul.2015 at 00:15
Well if you are just copying some of the objects in a drawing then you have to pick only those objects.  However, if you pick just one object but all the objects in the drawing are highlighted then you are dealing with a block that must be exploded first.
Are you an AutoCAD newbie?
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCad2017
Status: Offline
Direct Link To This Post Posted: 03.Jul.2015 at 03:34
John, I'm not a newbie, use AutoCAD since 1995 when used with MS DOS environment.
The drawing is not a block, as I said goes for all drawings, so the question whether it is a system variable.
I have Autocad installed on other computers and it's not the same.
An apology if my English is not very clear but my language is Spanish and I do my best to make me understand
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 03.Jul.2015 at 12:14
Then you're dealing with groups.
Upload a copy of the drawing or use a file sharing service like Dropbox.  Your explanations just aren't clear enough.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCad2017
Status: Offline
Direct Link To This Post Posted: 17.Jul.2015 at 18:38
Finally the problem was in the Options window, in the box selection modes in Use Shift to add to selection, for that reason passed if not select all at once, so do not take the same time without shift went off the selection.
Thanks to those who tried to help.
Embarrassed
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,438 seconds.
