CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
  Visitors: 9853
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedSnap Options / Munipulating 3d Objects - Need Help
 Post Reply Post Reply
Author
Create View Drop Down
Newbie
Newbie
Using: AutoCAD2015, Revit2015
Status: Offline
Direct Link To This Post Topic: Snap Options / Munipulating 3d Objects - Need Help
    Posted: 25.Aug.2015 at 16:31
I am fairly new to AutoCAD and have been trying to teach myself, so I'm very thankful for this website and the community it brings with it.
Images Attached.
Goal - To add a door frame and attach the sidewalk to the door, flush.
Problem 1 - Adding a door frame but having trouble with UCS and possibly object snap. I can't highlight the wall I wish to work on, and if I do end up getting the UCS figured out, Is there any problems I will run into with cropping out a door frame (Linear Cuts) into a wall which is non-linear?
Problem 2 - How do I take a 3-d spline and attach it to the door frame flush?
What I have tried - First thing I tried was this
#1
1) Command line - UCS
2) For assigning the X-axis I was stumped on because the Axis I would like to run in along is a polynomial so I figured this wont work so I just entered "World" instead.
#2
Messing around with object snap options but had no luck.
Problem 1 -
Problem 2
Your help is much appreciated.
Edited by Create - 25.Aug.2015 at 16:35
Be the change you want to see.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 25.Aug.2015 at 16:35
Are the door and the sidewalk at different elevations?
Why are you using a spline to construct the sidewalk?
Adding a door frame in a curved wall does take some doing.  Did you try punching an opening in the wall first?
What is the wall thickness?  What are the dimensions of your door?  What is the radius of the curve used to define the wall?
Edited by John Connor - 25.Aug.2015 at 16:44
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 25.Aug.2015 at 17:19
Hi John,
- As far as I am aware, they are at the same elevations.
- Let me first give you a little information. I am trying to learn AutoCAD so I figured, after watching many tutorials and following along, I will create a drawing from scratch. I walked around my city and took note of structures that I have not come across in AutoCAD so far. This drawing is just a compilation of buildings and features I have seen in my city. I figured I would come across many problems and this is why I wanted to do it.
Back to your question #2. I am using spline to create a sidewalk because I wanted to add a sidewalk which "Bends" if that makes sense. The only way I figured I could do this is by using Spline and going from there. I am open to any other suggestion which will allow me to create sidewalks which have sinusoidal shape.
- No I did not try punching an opening first. I will take this into consideration. Thank you.
Wall thickness - 12"
Door Dimensions - Height 7' Width 3' Thickness 1 3/4"
Radius of curve - How can I check for this if the curvature is on a spline?
Sorry to make this such a hassle, I don't know much about AutoCAD but really want to learn this software. This is the first Software I've ever worked on.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 25.Aug.2015 at 17:58
The height of a common door is 6'-8".
Why is the wall 12" thick?  Is it a masonry wall comprised of concrete block and brick?
To create the sidewalk I might have used a reverse curve.
You used a spline for the curve of your wall too?  Shouldn't you learn to walk before you try running a marathon?
Where are you located exactly?
Can you upload a copy of the drawing to this website (in CAD block area) or make it available via Dropbox or another file sharing site?
Edited by John Connor - 25.Aug.2015 at 18:34
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 25.Aug.2015 at 19:19
Curved wall (12") with a 36" wide opening and 4" thick concrete sidewalk.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 25.Aug.2015 at 22:39
-- I haven't had ANY experience in this world. I am just beginning. I am going to make a ton of ridiculous mistakes but I am willing to fix them and do what I can to improve, with that said, I don't have exact answers for all of these questions. Like I am just trying to guesstimate numbers and get some experience on AutoCAD. I have no help other then this forum, videos online, and books (Which should be enough).
-- I would like to use concrete. After reading some forums it seems like 8" should be thick enough. This isn't actually going to be constructed.
-- Okay I will try it again using reverse curve. Thank you.
-- Of course, I am not trying to leave my level of knowledge, I'm simply trying to challenge myself to improve. If you have any recommendations for beginners I am willing to listen. I didn't know any other way of doing this other than using spline.
-- South West Florida, Tampa Bay Area.
-- Yes I uploaded the file onto a public Dropbox account. I just need an email address to send it.
- Thanks again.
Edited by Create - 25.Aug.2015 at 23:11
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 25.Aug.2015 at 22:50
That is the goal. =)
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 25.Aug.2015 at 23:25
The only spline used was for the wall.  The reverse curved sidewalk was done using the Circle command.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,492 seconds.
