CZ | EN | DE
Login or
registration
  Visitors: 4584
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedAutoCAD2012 -Hanging/Freezes on "Open" Command
 Post Reply Post Reply Page  12>
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Topic: AutoCAD2012 -Hanging/Freezes on "Open" Command
    Posted: 24.Aug.2016 at 18:02
Good to hear.  You're welcomed.
<<AutoCAD 2015>>
Back to Top
SAMLERMAN View Drop Down
Newbie
Newbie
Using: AutoCAD2012 AutoCAD2016, Revit2016
Status: Offline
Direct Link To This Post Posted: 24.Aug.2016 at 17:12
It works! Thank you very-very much!
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 24.Aug.2016 at 11:13
DropBox of course.  Update to version 8.4.20.
Edited by John Connor - 24.Aug.2016 at 11:15
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 24.Aug.2016 at 01:19
Reinstall Dropbox or AutoCAD?
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Aug.2016 at 23:33
I just read that the problem has been linked to DropBox and the fix is to uninstall the program then reinstall it.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 23.Aug.2016 at 22:43
BTW, the (command "appload") helps!
Thank you!
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 23.Aug.2016 at 22:25
It will be the same as creating a new profile when I start new session-it fix the problem for duration of this session/
Anyway, thank you for trying to help!
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Aug.2016 at 20:09
Someone posted this temporary solution at another AutoCAD Help site.  For what it is worth.........
It must be a Windows update because I got exactly the same problem on several computers at the same time. I made it work again by placing this line into the "acad.lsp" file:
Code:
(command "appload")
It brings up an "Load/Unload Application" dialog right when I start AutoCAD. I just cancel that and from that point 'open', 'saveas' and 'insert' all work fine.
In your case (LT), try to go to Options>Files tab, click on "Support File Search Path", highlight any path that opens and then click "Browse". "Browse For Folder" dialog should pop up. Just cancel that and cancel Options dialog and you should be good to go. It should fix the problem for duration of your drawing session. You will have to do this every time you start the AutoCAD, until Microsoft fixes the problem in some next update.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Aug.2016 at 18:36
You are like the fifth or sixth person in the last two days that I read of having this particular problem.  Someone said they thought it happened right after a Windows update.  We haven't experienced it however.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 23.Aug.2016 at 18:26
AutoCAD2016 works perfect
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,438 seconds.
