Over 1.096.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
Try the new precise Engineering calculator and the updated Barcode generator.
New AutoCAD 2026 commands and variables.
Discussion forum
Post Reply ![]() |
Page <123 |
Author | |
Vladimir Michl ![]() Moderator Group ![]() Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2121 |
Just download the latest version of fArea (see Download). Load (APPLOAD) the fArea.vlx and start the FAREA command. On the first prompt, enter "S" for setup. Specify the label suffix, multiplication factor (0.000001) and the number of decimal places. Pick the closed geometry (polyline, circle..). Either select a predefined text label (any text) or press Enter to specify a new text entity - pick the insertion point, the text size and rotation of the new label.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
MarkWT ![]() Newbie ![]() Joined: 06.Nov.2008 Status: Offline Points: 3 |
Hi All, New user here. Found the 'farea' tool via a post (& link) on this forum. Have downloaded it and installed it using appload. Thing is, I'm having real trouble figuring out how to enter the parameters when promted. Could someone please take me through the steps required to create a 'dynamic text label' with 250pt text size at an insertion point of my choice (ideally i'd just like to click the mouse where i want to insert the label) at 0degrees rotation. Also, my drawing is in mm but i'd like the areas displayed in m2 (i've assumed the 'multiplication factor' would be 0.000001 but it doesn't seem to work). I've been fiddling about with the setup and options for a good while now so any advice or an alternative method for measuring areas (lots of - quickly!) would be much appreciated.Cheers,
Mark.
Post Reply ![]() |
Page <123 |
Tweet
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,074 seconds.
