Discussion forum
CAD discussion |
Creating 3D Objects Using Scripts |
Post Reply |
Author | |
austindfw
Newbie Joined: 28.Dec.2018 Location: United States Using: AutoCAD2016 Status: Offline Points: 4 |
Topic: Creating 3D Objects Using Scripts Posted: 28.Dec.2018 at 02:29 |
I'm looking for good reference resources for creating 3D objects using scripts. Can you create cylinders, etc. using scripts?
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 28.Dec.2018 at 14:40 |
Have you written any scripts yourself?
<<AutoCAD 2015>> |
Kent Cooper
Senior Member Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 629 |
Posted: 28.Dec.2018 at 17:19 |
I went to the AutoCAD Customization Forum and just put "cylinder script" in the Search window, and got >>this<<. But another question comes to mind: Are you asking about SCRIPTs in AutoCAD's meaning of the word? A lot of people use the word more loosely, to refer to any kind of coded routine or function, including such things as AutoLisp routines or command macros. But SCRIPT has a specific [and different from those] meaning in AutoCAD -- is that the one you intend?
austindfw
Posted: 30.Dec.2018 at 00:56 |
Thanks
for the reply. I’m just referring to the scripts run using the SCR command. The
intent is to learn the capabilities of creating and manipulating 3d objects
using scripts. However, if there are other API’s that you think are better
suited, please let me know.
Post Reply | |
Tweet
This page was generated in 0,367 seconds.
