Discussion forum
CAD discussion |
Purge |
Post Reply |
Author | |
philippe JOSEPH
Senior Member Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1428 |
Topic: Purge Posted: 10.Jul.2019 at 21:12 |
Hello roel-nahuis and Kent, if you want to have access to all type of entities that you have created you should begin every drawing whith your template or "prototype drawing" and leave it untouched in a place of each of your files so that even if you launch a big PURGE you have access to : dimensions styles, layers, blocks, etc...
If you want them back then re-insert your template or "prototype drawing" or do a simple copy/paste of what is missing.
Edited by philippe JOSEPH - 10.Jul.2019 at 21:15 |
Kent Cooper
Senior Member Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 629 |
Posted: 10.Jul.2019 at 14:32 |
Do you mean Dimension Styles that you have not used are gone from the drawing? That would be normal PURGE behavior. You can choose which kinds of things to remove in the Purge dialog box. Or if you use a command-line -PURGE command, you can select the kinds of things as options there. In either case you need to work on each kind separately -- as far as I know, you can't say "Purge everything except Dimension Styles." Or do you mean that Dimension objects that you have drawn are gone? If that is what's happening, something is really wrong....
roel-nahuis
Newbie Joined: 20.Jun.2019 Location: Germany Using: AutoCAD2019 Status: Offline Points: 6 |
Posted: 10.Jul.2019 at 08:25 |
it's just the dimensions what i have not jused jet from my template
Vladimir Michl
Posted: 10.Jul.2019 at 08:22 |
PURGE should never touch referenced (used) objects. Are there any errors when you AUDIT your drawing?
Vladimir Michl (moderator)
roel-nahuis
Posted: 10.Jul.2019 at 08:02 |
hello,
when i puge my drawing all my dimensions are gone. is it possible to lock my dimensions?
Post Reply | |
Tweet
This page was generated in 0,330 seconds.
