Discussion forum
CAD discussion |
PLACE BLOCKS ALONG A POLYLINE WITH DIFFERENTS DIST |
Post Reply |
Author | |
wmoura
Newbie Joined: 20.May.2020 Location: Brazil Using: AutoCAD 2019 Status: Offline Points: 2 |
Topic: PLACE BLOCKS ALONG A POLYLINE WITH DIFFERENTS DIST Posted: 20.May.2020 at 00:16 |
Hey guys! How's going? Well, i have a problem with block placement: i need to place a lot of blocks along a extensive polyline but the distance of the block isnt equal and the blocks are differents. I thought in create a list with the block id and distance from the polyline beginning. Using that list as parameter, i'll can place all of the blocks of the list with they distance. Can anyone help me? The list have this layout: BLOCK NAME | DISTANCE B1 | 245 B2 | 154 B3 | 641 B4 | 321 Thanks! Much love from Brazil! Wellington
Vladimir Michl
Posted: 20.May.2020 at 06:53 |
Please look at the TraceCurve utility - maybe it can be used in multiple runs (for each block) or we can customize it for the task you need.
Vladimir Michl (moderator)
Post Reply | |
Tweet
This page was generated in 0,414 seconds.
